oil leaks solved: P-traps for oil return lines
Hello to all,
a few months ago I had a batch of modified oil return tubes fabricated to solve the leaking of oil from the turbos. Prior to the modified lines this could happen when the oil level was at maximum and after prolonged times of non-use of the car.
https://rennlist.com/forums/9346787-post1.html
The batch of these items is almost finished up and for the ones who still would like to modify the oil lines I can instead offer the inox p-trap tubes only of which I still have a few in stock. These p-traps cost less (220 USD included shipping) but your mechanic has to fit them in the existing oil lines by soldering.
http://www.zweisteintrading.eu/p_traps.htm
Best regards
Andreas
Best regards
Andreas
