:: ECS Tuning:: 993/993T Oil Service Kit, Now Featuring MANN Filters
Protect your Porsche 993 or 993T engine. Don't let dirty crankcase oil and clogged filters lead to engine damage and expensive repairs.
Our convenient oil change service kits have everything you need to perform a professional quality oil change service.
Each kit contains top shelf synthetic LubroMoly oil and two Mann premium filters, plus sealing washers to prevent annoying leaks.
Don't settle for lesser products or incomplete kits. Your Porsche deserves the best.
Demand Excellence
For more information, click here.
I read the ad and was just waiting for the reaction - it shows that ECS missed the mark on this one - I think that oil is too thin even for a NA 993, and MANN filters on a Turbo???
I fully understand the stance of some aircooled owners that do not wish to use 0-W40, however, it remains factory recommended weight, and some owners will not use anything but what Porsche recommends.
For those that are concerned about the low weight, we do offer Brad Penn oils in a variety of weights that you may find more acceptable.
Aside from the fact that Porsche trusts MANN to produce their OEM filters, I have never had an indication that MANN produces anything to a substandard level. Their high quality production standards are what led us to use their filters.
If it would ease anyone's mind, I would be glad to personally analyze the OEM Porsche filters side-by-side with the MANN branded units.
I think the concern raised repeatedly in the past is the cars that have used the mann filters have had problems with smoking and leaking turbos, from the smaller filter not haveing an adequate check valve (with cars developing this symptom after change to mann and resolving after going back to Porsche filters). I would be interested if there is a way to see actually if there is a structural difference between the Porsche and Mann small filter - valve design/spring tension etc or wether things are identical.
I doubt if anyone can say if Mann has two variants, with the Porsche branded filters being different, but for the cost difference of a few bucks, I will stick to filters from Porsche directly.
Next time I get a Mann small filter in the shop, I will save it and take it apart, and compare to the Porsche filter.
Cheers,
Mike
My wrench also confirmed this when he investigated the oil Filter concerns here on the board. Even cut open a "porsche" filter and compred them. So it does appear that Porsche brand filters bought at your dealer are made right here in the USA by Purolator. With that being said I still run only those and have had no issues so far.
Porsche did make a change in the small oil filters - see this bulletin http://www.pcarworkshop.com/images/3...0395geolab.pdf. I do not know if the Mann filters followed as well. I also do not know if the changes can be seen easily if the filters are taken apart.
Again, since there are unknowns and evidence for Turbos that non-Porsche filters may cause issues, its better to stay safe and stick with Porsche brand, at least for the Turbos.
Cheers,
Mike
Mike,
The bulletin you show is copyrighted "1995", perhaps in the earliest stages of 993 Turbo production. It also lists the NA part number as being 99310720301, and the Turbo number as being 99310720302. Both numbers supersede to the current 99310720303, which is the number both MANN and Mahle use for their iterations. Whatever changes have been made to the Porsche unit, they have also should have been carried out on the aftermarket units as well, in order to carry those numbers.
I will continue to research this. Please let me know if you have any questions.
