Anyone near Maplewood Porsche in MN?
Tony, have them fix it! Nice car!!!!
Boost Junkie
wonder where this car came from. I've never seen a guards red tt locally. good luck. If Matt can't make it, I'd be happy to take a look but I'm a little farther away
I'd want to look closely at this. Isn't that a common are for rust? If it's rust causing the bubble, it's going to be more complicated than they might want to admit and more complicated than you want being done without proof.
Yeah, water gets trapped under the seals around the rear window and rust forms. I wouldn't have the dealership do a thing, I'd have it shipped back to you in CO and deal with it there with the sale price adjusted accordingly. Obviously have a PPI done including paint/body work check. Good luck!
Thanks guys for the input.
Car is going for a PPI at Auto-Edge just down the road. I will learn the extent of the rust bubble, and how oil got into the turbos.
They did put on Porsche OEM filters this morning which may have been the issue all along.
See if you can find out if they took off Mahle or some other aftermarket oil filters. There are a couple of "smoking turbo" threads going right now, and this may be more fuel for the fire and help others out.
I recently went thru this repair, once my rear window was removed even the bodyshop (who has experience doing these types of repairs) stated it was surprising at the amount of rust + holes that was there. You could not see most of it with the window there, even with the seal removed.
You need someone with experience for removing/installing the rear window, so best to get this done thru your own sourcing. Removing window is a must to do the job correctly.
I would just factor a repair cost into your buying price.
Good luck!
I confirmed today that my car has Porsche OEM filters on it , yet it started getting blue smoke this past weekend. Don't be too sure the problem will go away just becauses a Porsche filter is installed.
Also, Isn't oil on the turbo's an expensive problem?
Thanks Onami, will do!
Confirmed it was NOT Mahle filter. Hmm...
I have seen a post (maybe yours) where the rust went on and on, quite alarming. I have the PPI tomorrow and he promised a thorough look.
Many thanks!
I believe its a "depends" answer, how long its been in there....check out this thread I found from Kevin on worst case scenario.
QUOTE=Kevin;9447312]You guys are foolish allowing ANY race shop or indy for installing the Mahle (Mann, Bosch, Fram or XYZ) vs the factory Genuine Porsche filter.
Here is the problem>> buy the time you catch the oil filter problem, your turbochargers are soaked with oil. You are driving the car burning the oil which is getting cooked in the heat shield and is wearing out your turbine side sealing rings. Your turbochargers are going from a "good" status to a "WORN" status when this issue is present. The secondary effect is BURNT and UNBURNT oil flowing into your CATS. Plugging the cats> sucking the life out of them and eventually putting all the backpressure on you exhaust valves/combustion chamber.
With that said, if you have a shop that is too lazy to install Porsche filters, do the oil change yourself or take the car to another shop or Porsche dealer. If you take the car to a Porsche dealer >>be careful most will fill the engine with 0w40 engine oil which is too thin for the air-cooled engine. The piston to cylinder clearance is to large for the 0W.
Lastly, every car that has suffered this FATE needs to have a engine leakdown done. Every month I get the call about a failing 993TT, to find out that it really needs a topend overhaul. At 15% leakdown the turbochargers will push oil..
/QUOTE]
Many thanks!
Be aware that the rear rust is deceiving, it can be a lot worse than it appears.
Good luck!
Good luck!
/QUOTE]
I'm holding out my excitement or disappointment post PPI tomorrow.
I haven't had a 993 without any issues, so I'm really just trying to scope the extent of it. If its bad, I will pass. If its fixable, I will own a 993TT tomorrow.
I have been following this for a bit. GREAT people here on this site. Saved my *** many times.
But what you need to look at is what is an acceptable repair on a car of this age. Sounds (on the surface) that this car has some issues to deal with. But not HUGE. Just my .02.
Remember you have a car of this age and power. It will have issues depending on the previous owner. You are buying from a dealer and all they wish to do is turn a profit.
This is a great forum. Been here for a LONG time. Great people. But all of us are at different "Snack" levels per si.
PPI report came in:
1. Rust bubble on passenger side front windshield, no further damage ($unsure)
2. The filter have been changed out, no longer oil spillage into the turbo.
