First Oil Change and Oil Analysis for my Turbo
I posted this on the 993 forum if anyone is interested in seeing a UOA on Pentosin used in a Turbo.
https://rennlist.com/forums/993-foru...-my-turbo.html
The chart on this site: http://www.lnengineering.com/oil.html#Z11
says that 20W50 is okay to 20F, but if you are doing repeated cold starts below 32F then 15W40 is better.
Thanks. That's the table. OK to -10C. I like to go for a spin when it's sunny and dry probably 4 times a winter but I won't start it unless the garage temperature is over +5C. When you only drive 2K miles a year, and do a few spins a winter, thinner oil isn't really worthwhile.
just go by the data sheets
US M1 V-Twin
http://www.mobil.com/USA-English/Lub...ycle_Oils.aspx
OpieOils has a bunch of datasheets to compare coldcranking and pumping - if you can't find them on US websites
http://www.opieoils.co.uk/t-oils-by-type.aspx
