Looking for a stock IC shroud...
haha nothing that cool. I fabbed up some proper ducting from the GT2 wing and it looks like the shroud needs to be modified slightly. My current shroud has the top hole welded shut and is painted flat back and i would hate mess it up.
My hope is someone has a take off from an aftermarket IC and they would be will to part with it for some $$$
None of the dismantlers seem to have one. Last resort is I fabricate one out of aluminum
Thats pretty close to what I would do. Right now the intake is completly closed in (except for an area on the front to allow air flow through) so once the air comes through the wing it flows right over and against the air filter. The other side will flow over the top of the IC.
What took a while was getting the air funnel/scoop in the wing itself to be smooth and strong enough to change the direction of the air flow at high speeds.
Update if anyone cares ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Brand new from sunset its $116! They are only in Germany but for another $20 it can be here in less than a week. Much cheaper than I would have suspected
