I always knew my car had 2000 hp
Hey Felix if you use my rational, it works out pretty similar to your calculation ie. 1043HP !
(much more math though aargh...)
300km/hr = 83.33 m/sec
deceleration 83.33/6.8 = 12.25 m/sec (squared)
1500kg car
1500x12.25 = 18382 Newton
tire diameter say 26” = 66 cm=0.66 m
r= 0.33
18382x0.33=6066 nm
so rpm of wheels
0-300 so average speed assuming constant (average deceleration) 150km/hr = 41.67m/sec
26” wheels = 66cm dia -> 0.66x3.14 = 2.07m circumference
so 41.67m/sec x 6.8 sec = distance travelled =283.6 m
so rotations = 136.9
RPM = 136.9 rotations/6.8sec=1207.8 RPM
RPMx2pi/60 = 1207.8x2x3.14/60= 126.4 radians/sec
126.4x6066 = 766742.4 watts
766742.4/735=1043 hp
1500kg car
r= 0.33
18382x0.33=6066 nm
so rpm of wheels
Rennlist Lifetime Member
I think other corrections like air drag and moments of inertia need to be calculated in too... but I'm starting to get a headache...
I've got a gtech pro somewhere - I'll see if I can find the manual for it, seem to remember some descriptions of some calculations in it. Seem to remember being able to estimate drag by coasting or something.
Hey Brian, I is just a failed engineer - wimped out and joined management!
I think the key might be here:
Maybe braking capability and measured braking are not the same thing! This car might have braking capability of 2000 HP given the right conditions.
As tested by Sport Auto, the 993TT goes from 62mph to 0 mph in 34 meters, that is ~1.2Gs of deceleration and about 2.5 seconds. This is about the limit of traction for street tires. If you move to slicks and test on a sticky surface, you can well see above 2Gs of braking force, your braking distance will be cut almost by half and time required as well..
If you factor a heavier weight (2 + 2 people on board + luggage), you can be adding about 300kgs of weight.
Given that the claim is that they have "capability" to brake at 2000HP, it might be justified one way or another.
ALl of the above is meaningless...let's get those GPS devices.
