Thinking of doing this mod. What do I do about the pressure plate? Just buy a 993 RS 3 piece kit and use the pressure plate in that or buy the parts on their own and get the turbo pressure plate?
890nm Clutch is the best part of £850, and the flywheel is £350. So basically the same price as what Kevin is offering! Where can you get it for cheaper?
Just curious why you are changing to a lightweight flywheel if you are at stock power? I understand it may rev a little quicker, but it's negligible.... The only thing i noticed really was a it became a tiny bit more responsive and a lot more noisy through the transmission. If you're going for a stronger clutch to cope with more power, then you may as well throw the lightweight flywheel in while you're at it
