Momo Steering wheel install help needed. Horn sounds when wheel is turned.
I still cannot for the life of me figure this out and hope someone on here has the solution:
Momo RS Steering wheel, MoMo adapter, proper Genuine Porsche horn adapter, followed directions given elsewhere on the board with exception that the wire colors were incorrect and made note on the thread.
Problem is, with ignition turned on but engine not running, the horn sporatically sounds as the steering wheel is turned. Horn works from botton just fine...but cannot figure this out.
Pulled ground. No change.
Pulled each of two connection to horn button, no change (except horn does not sound when button is presed)
Pulled BOTH wires to horn botton. Same as above.
So WHY is there still power to horn and where is it coming from?
Please tell me SOMEONE has had this issue...
