993 Turbo Forum 1995-1998
Rufus needs rear tires (again!!!!!!)
Old 11-05-2010, 04:42 PM
ca993twin
ca993twin's Avatar
Thanks for all the advice guys. I am having the two tires drop-shipped to Dave at Custom Alignment and he will mount and set a less agressive rear camber.
Old 11-06-2010, 09:13 AM
No HTwo O
No HTwo O's Avatar
Originally Posted by sfbanchs
try treaddepot.com
This is a great web site. Their prices (on a quick check of a few sizes) were about $20 per tire less than Tire Rack. Will use in the future. Thanks for posting, Sfbanchs.
Old 11-16-2010, 12:55 AM
ca993twin
ca993twin's Avatar
Rufus is done! Custom Alignment was great. Tires were mounted then rotated to minimize the required balance weights. Alignment was off a bit, and the kinematic toe was way off. The eccentric bolt required to adjust the toe was stripped and had to be replaced. The total was a bit expensive, but well worth it. Rufus is handling GREAT, even with a bit less negative camber all around. I'm a happy camper. Treadepot.com delivered as advertised.
Quick Reply: Rufus needs rear tires (again!!!!!!)
