993TT Valdez...pentosin
I have this problem now. It's good to read things on rennlist even if it isn't a immediate concern it seems. I had noticed some wetness but though it was just from me filling oil too quickly as usual - but it's not oil. Just tightened the banjo since it was not very tight but the whole line is a little sticky/moist so suspect it needs to be replace. Had a friend a few years ago dump pentosin on the track with a lot of drama I suspect from this line failing. So just ordered one. Do you need to bleed the system somewhere once this line is replaced? I suspect one does.
No bleeding required - its self bleeding. Just watch out, its the feed line from the small tank, so there will be Pentosin everywhere. You can pull some from the tank (I use large syringes) before you disconnect.
Cheers,
Mike
Cheers,
Mike
The line that i had issues with was essentially just heater hose. The line was fine. I just needed some nice new hose clamps and to snug it all up.
good luck
good luck
I hope you were successful. When we had hard to find leaks in the boat yard we would clean and dry all and then apply talc. This would clearly show leak location...sometimes multiple mirrors had to be used to see the leak......Chris
using talc is a good idea!
So you just took the crimped part off and used standard clamps on the old hose? The line/aluminum block(check valve) vibrates on the rubber holder with the engine running and likely what leads to the failure of these. I'm thinking your standard clamp idea might even be sturdier (and cheaper).
I put a good old made in china worm clamp on there.
I'd imagine over time the crimp style just don't stay tight enough.
Just finished putting the new line in, PITA...had to undo the other line at the silver box/check valve to get this line off at the box. Used a crescent wrench to hold the box.
Supposed to be upgraded (apparently not too uncommon failure) and was going to take a pic but it looked virtually identical so didn't bother. I changed the gas filter at the same time. I changed the gas filter once before when I got the car but how I did it without taking this line off I can't remember.
