Pics of my GT2 Conversion
#32
How do you handle the ebrake with the fabcar, can it be kept intact?
Also what wheels are you running, im especially interested in the width up front?
Will send à couple of pics on my car.
Cheers P
Cheers P
#33
Yeah stock Ebrake.
BBS 3 piece i believe fronts are 10.5 or 11 rears are 13, ill check later when i get home.
when i did the RWD conversion changed all the suspension components to either rs or factory Gt2 to get the correct stance, height and tire width.
#34
10.5 fronts? I was wondering why they front was kind of high. What front brakes are you running? With 380's I could only get a 10 inch front max before i was rubbing all over the place
#35
Thanks,
seats are replica Gt3 seats Rick at DeMan sells, can do any color combo in alcantara or leather with deviated stitching, roughly 1700 each.
Brakes are stock, the height of the car was set to factory Gt2 height. The shop had an actual Gt2 there while mine was being done so he was able to copy alot of details such as ride height. i went a little wider width tires, using the 3 piece BBS which is really the only option as you have to play around with the width of the center section to get the right width.
I removed all of the wheel well plastic and what not to allow for the width.
#43
