Best place to source Wide Ovals?
In the midst of setting up my new TT and probably going to go with a set of Fister mufflers.
I need to find a set of wide ovals as the ones on the car are damaged and the Fister tips might stick out a little more than I'm comfortable with.
I picked up a set of Wide Ovals for my cab back in the day and they weren't OEM which is fine, but I can't seem to find a source for turbo tips.
Appreciate any suggestions...
Thanks!
Thanks!
Only issue is I know the Turbo is different from NA cars.
Here is one listed but not sure if they will fit?
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
Sunset - roughly around $600+. Turbo tips are longer..
EP7110 or EP6110 OR ep5110...one of these, can't rem which one.
993 Guy. here are the non-OEM tips I can send you:
The back side circle is approx. 62mm inner diameter
The oval is approx. 120mm x 80 mm
The lenght of the chromed area is approx. 110 x 80 (not sure about these measurements):
993 Guy, using Trinitony's picture above (post #8) the tips I have are approx. 162mm at the tallest point. How do we know if these are the "narrow body" tips or the "turbo" tips? Thanks.
I'll respond to your PM ASAP. They are ready to ship out today if needed.
