RUF Bumpered Green 993TT
Rick,
Bring that thing in my neighborhood and I'm calling the cops!
Its looking really good - and I'm looking forward to seeing it run at Grattan this weekend, will take some pics of it in flight.
p-cardriver
p-cardriver
The suspension is PSS10 with RS bars and the tires on the car are Toyo R888's. That was the first time I ran with the R888's thinking that they would would good in what was to be a mixed wet/dry weekend.
Was not happy with their performance compared to the Nitto NT01's I normally run. Times were a couple seconds off what I normally run but the track was green and nobody was making their numbers. So I would say it was more me than the rubber. I am sure they would work out better if I had taken the time to play with the set up which is well sorted for NT01's.
Rick
Rick
Rick,
can you fit 315 in the rear? also I’m assuming you are running straight pipes?
sorry for all the questions, but I’m working on my car(track-car) and it is very similar, two wheel drive, ruf front and rear bumper covers, jrz,RS brakes,996tt wheels, etc. Thanks for the info....
R
R
Yes a 315 NT01 fits fine in the rear but the 315 R888's will just rub depending on your camber setting. I cut my fender lip back a bit just to cover backing off on the camber. Yes the exhaust is straight out.
Rick
Rick
