Front P93T replacement rotor
Just got this replacement rotors from Martin @ Girodisc for my 993tt. They had done measurement on my stock rotor a couple of months ago and today I got the the replacement rotors.
My old stock rotor weighs 20.4 lb while this new one weighs 17.8 lb each, probably even lighter had I cross drilled them
Thanks Pram! Please post your impressions once you get them on. They look like they'd be great. What pads do you think you'll run? I just replaced mine with oem rotors and tried to use Pagid pads. Squealed like a pig but stop incredibly well. Ended up going back to the regular oem pads which aren't quit as good but still decent.
Would be interesting to compare these to the DBA 5000 rotors which are around $1300 set.
I have to say though, at these prices I'd start looking into the Brembo big brakes...
