993 Turbo Forum 1995-1998
Problems with Clutch?
Old 05-17-2010 | 12:12 AM
ca993twin's Avatar
ca993twin
Scott, I shame myself. Constantly.
Old 05-18-2010 | 01:45 AM
Axeman's Avatar
Axeman
Originally Posted by typer77
thanks guys!
Where can I find part number? To replace it, do i need any other parts/ clamps/ hoses?
Is there also an accumulator for the ABS? my brake pedal sometimes vibrates when I brake (even gently). It feels like ABS is trying to store pressure.
Clutch Slave Cylinder part # 993 116 237 52
Clutch Pressure Accumulator part # 993 355 109 03
I carry both items if anyone needs one..I'll give you the "RL discount"
Old 05-18-2010 | 11:09 AM
No HTwo O's Avatar
No HTwo O
What if we don't drive the car for a few days or a week? Will the clutch get "hard" again? Do we have the same clutch systems as the n/a 993 guys & gals?
Old 05-18-2010 | 12:53 PM
WHB Porsche's Avatar
WHB Porsche
I'm Still Jenny
Originally Posted by ScottMellor
Replace the clutch slave cylinder while you're in there. One pentosin bath is enough for anyone.
Steve, I am ashamed of you.
Yeah, but the slave is like $350 and the accum. is like $90.
I'd say the accumulator is a "while you're in there" part for the slave, but not the other way around. The slave cylinder is a good bit more involved than just a simple accumulator R&R.
Old 05-18-2010 | 01:02 PM
911/Q45's Avatar
911/Q45
The accumulator holds pressure after the car is shut off. It may slowly bleed off the pressure after a period of time, but it can't gain more pressure without the car running again. The turbo has a unique power assist clutch that is not shared by any other 993.
Old 05-18-2010 | 01:05 PM
ca993twin's Avatar
ca993twin
No HTwo O,
With a proper accumulator, the clutch can be activated many times after the engine is off. It will get hard only after many depressions. Then, the next time the engine is started, the accumulator is recharged, and all is good again. The Turbo uses a power clutch assist that is NOT used by the NA cars. That must be the reason the factory designed a fiendishly complex slave cylinder for our cars.
Old 05-18-2010 | 01:29 PM
ScottMellor's Avatar
ScottMellor
I agree with you Charlie, except that once one has gone the other seems to be not far behind.
Old 05-18-2010 | 03:09 PM
Quadcammer's Avatar
Quadcammer
List price for the slave is in the $880 range. You can get it at parts.com or sunset for about $700.
Accumulator is about $108 at these sources.
Old 05-18-2010 | 06:34 PM
993MAN's Avatar
993MAN
Is the accumulator a relatively simple DIY?
The picture posted here made it look easy, but then I'm not taking my engine out!
What needs to be moved out of the way?
Will I bleed much from my knuckles?
Old 05-18-2010 | 08:27 PM
Quadcammer's Avatar
Quadcammer
accumulator seems to be fairly easy to reach with small hands. Sits above the transmission. The shape makes it difficult to remove without an oil filter style wrench.
I'd say easy in concept, moderately difficult in practice.
Quick Reply: Problems with Clutch?
