First problem
First problem
Just had the TT for 3 weeks. Most of the time under wrap. Toady send the car for a wash. They moved the seats back. now i can move the seat forward. Its electric seat. Can adjust it up down etc but not forward or backward.Hmmmm first challenge
You might want to check the electrical connections in case they sprayed water inside or a fuse or if a coin got stuck in the seat rails. Otherwise, you might want to take a look at this.
http://p-car.com/diy/seatshaft
Easy fix. Read through the below past posting. Let us know how it worked.
https://rennlist.com/forums/993-foru...ward-help.html
