OT: After 993 tt
GT3 player par excellence
Ford GT for sure. I bet you'll see a lot more gold chain-ed drivers in an SLS. Every Ford GT owner I've met is "one of us"! I'd take one.
But, as someone else suggested, I take a GT2 over either one
I've met two FGT owners who have or had 993tt modded and they all say the same thing, go for it. Downside, I found cases of overheating at track events. on warm days even with unmodded cars.
The SLS will most likely be over sold ( est 4000 @ yr) I'm convienced but it's spec's are an Amg clean sheet of paper with awsome capabilites. Tommy Kendall ran laps at 1:37 with passengers at Laguna Seca on Conti's with a 280 wear rating! Lately AMG's have taken a huge depreciaton wack but this might be different as it's not just a big engine in a sedan.
My goal is a drive to the track with 600+hp that can hang with the race cars and drive home.
For some that suggested a Gt2, it's not in the cards for the simple reason, 600hp rwd porsche inspite of electronic nanies, are a handfull. Walter Rohrl can make them go fast, but he has gonads the size of Godzilla. Jeremy Clarkson said it will KILL YOU maybe a little theather, but true.
So FWIW, it's pretty hard to find and replace a well modded 993tt.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Rennlist Lifetime Member
As I have said in your other thread, 997GT2 (or 997GT2RS if they make it AND it comes to the USA), otherwise, I would buy another 993TT (or 993TTS) and modify again. After you drive any other car for a month or two, you WILL have seller's (of the 993TT) remorse.
Also, I'd expect a 997 GT2 to be no more of a handful than the Ford GT. The 997 chassis is amazingly benign (you realize, in this forum, we will continue to swing you in the GT2 direction
Hey Jim. How about a CGT? It's much lighter than the FGT and should have more performance potential than the FGT, especially with the inbound suspension, carbon tub and ceramic brakes. And better aero as well.
1. Raise kit for the street.
2. Slicks, exhaust, 9000 rpm redline, and cams for the track. One or two local guys seem to know how to do this for 650 HP+ normally aspirated! I think Porsche Motorsport may have something as well.
JJ................come back.............you now you want to and yeah, you made a mistake......so what?.....we all do it from time to time. but come back now.................we want you back and they, (the followers of whatever else you may buy), wont appreciate you the way we do....................just come back now!
I've seriously looked at the CGT, and you've pointed out one of the major flawes and that one would need a kit to raise it as it won't make it over speed bumps. Secondly, despite porsche claims the clutch is clearly a weak link and would have to be upgraded to the 9ff version for any track duty. I spoke to one owner who's had to replace a transmission for $50k not covered by warrantee due to track use! I've had several track day encounters with the CGT more horsepower isn't necessary. Getting it not to bite your head off is a different matter. FWIW, at California Speed way, a FGT was the fastest street car running roval.
just saw a Ford GT around town yesterday. It is truly a great looking car. Not to mention, even GT parts will seem cheap compared to some of the porsche stuff.
The aluminum 5.4 block is literally a work of art, and its only about $3k
The porsche factory did the 993tt a big favor, they raced it and that begot tons of race parts that none of the H2O porsche can claim. Ok I due miss....I can't go there.
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Bill,
I've put over 7,000 street miles on my CGT. The front spoiler scrapes often (but is not damaged), but I haven't damaged anything else under the car except one time at high speed over a deep dip. I had to replace the two rear fins and the carbon underpans got a little scratched, but just in the clear coat. I haven't come across a speed bump I couldn't clear, but I do recall turning around for some really gross ones!
