RWD conversion instructions
Does anyone have the instructions to do the RWD/2WD conversion? I bought the parts from ViperBob but he forget to include the instructions and haven't been able to reach him.
I'm guessing it's pretty straight forward and instructions are probably not necessary but since they are out there I figured I might as well read through them before I dive in.
Thanks,
Thanks,
Some folks from this thread might be able to help if you can't find the instructions you seek.
2wd Conversion
2wd Conversion
2wd
I also need this since a am planning to do this very soon.
Please send to:
tommy.karlsson@se.talaris.com
Best regrads Tommy
Please send to:
Best regrads Tommy
Looking through the manual I found:
39 88 19: Removing and installing front-axle final drive
39 03 19: Removing and installing central tube
40 41 19: Removing and installing front drive shaft
40 05 37: Dismantling and assembling suspension
Then using PET6 illistration 401-05 I can see the layout of the hub / shake proof washer / bolt.
Is there anything else I'm missing? Any help or words of advice are appreciated.
Guys - I might go down this route soon and wanted to better understand the procedure. It appears that the FD kit is the way to go. Can someone send me a PM with a DIY?
