2WD conversion
I realize this is a somewhat controversial topic, but I have never been a fan of the 993tt's AWD system--I don't like the effect of mid-corner torque transfer, and I feel this problem is exacerbated with increased power (courtesy of Kevin at UMW). I had been toying with the idea of going 2WD for a while, and yesterday I took the plunge.
Here's a comparison of the AWD (left) and 2WD (right) parts:
![](http://farm2.static.flickr.com/1301/1238146957_4316bc1542.jpg)
I also changed the front swaybar at the same time (TRG 25mm). The rest of the parts are factory Porsche parts purchased from Viper Bob.
The conversion job is not difficult, though wrestling with the torque tube is not much fun. Once you have all the AWD bits removed, it's only a matter of modifying the RWD shifter box and welding it to the chassis (just a few tack welds). The whole job took me about five hours once the car was on jack stands in my garage.
The conversion is completely reversible if I ever decide to sell the car.
I don't have much seat time yet, but my initial impression after a short drive yesterday is all positive: Steering feel is improved, the car feels lighter, and power oversteer is smooth and "natural."
Rennlist Lifetime Member
Thanks the photo; it's a great illustration (pun intended) of the different parts involved and the items which are removed. Any idea what the part numbers are for the stub axles and nuts that replace the front driveshafts? I'm guessing the drive shafts could be removed and replaced with those as a "try it to see if you like it" swap before going all the way and removing the front diff and torque tube.
They look like items 14, 15 and 16 from the following diagram from the PET. Their numbers are:
14. 993 341 155 01 shake-proof washer
15. 900 082 123 09 hex head bolt (?!) M22x1.5x200
16. 999 084 634 09 lock nut M22 x 1.5
Yes, those are the parts. It must be possible to remove the driveshafts with the front diff installed, but be prepared for lots of swearing in the process. Space is tight up there.
did you happen to get weights on the parts you took off? I have heard anywhere from 75# to 125#...
thinking about taking this plunge as well...thanks for sharing
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
I'm in the process of transforming my garage in to more of a "mahal", lift and all. Once its done, I think I'll make the removal my first christening of the lift
BTW, can I ask what VB charges for those parts?
jmayzurk,
Congrats on the conversion. I'm also in So. Cal. and will be converting to 2wd soon. Who did the work? Can you recommend the shop that did the conversion. Thanks.
The only independents in SoCal I have experience with are Callas Rennsport in Torrance (highly recommended) and TRE in North Hollywood (also recommended).
-Jeff
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Great work Jeff! I have been bugging Mike Lederer to do the same thing to his TT
I just do NOT like the way the AWD 993 drives.
Now you gotta get that front cover off the gbx and rid yourself of the VC and the weight it brings -- both static and rotating!!
