Spacers for 993TT's ??? 1" ?
okay so i found some... now i don't know if i should do 1" or 1.25"... I'm worried about the 1.25 being too aggressive, and causing some rubbing....
Has anybody used 20mm spacers on the OEM twists? I guess my real question is, will 18x10 +20 rub? I'm pretty damn low in the rear too...
For me, its about making this car look as pretty as humanly possible !!!
AHI, if you have the stock 18" turbo twists (10x18 ET40) in the rear, then 20mm is VERY aggressive IMHO. People tend to run 7mm spacers with the standard twists for a flush fit. It also depend on the tire and ride height but if you are running at low ride height and 285's in the back, I would stick with ½" e.g 12,5mm or 15mm maximum.
I measured with a tape measure from the corner of the tire tread, to about the inside corner of the fender lip, and I have about a 1.75" space... I figured the 1.25" would be aggressive enough without rubbing.... they will be here in a couple days and I'll hope for the best....
Plenty of Wheel spacers on EBAY:
http://shop.ebay.com/items/_W0QQ_nkw...romZR40QQ_mdoZ
BUt i would worry about the integrity of some of these.....
Steve is a good guy - will look after you..
Simon.
Simon.
Ok I see. I assumed you had the twist when I saw your avatar. On my C2S which is the same body I had 10x18 ET54 with 31mm spacers. It was fine but tight. I think the 1.25" spacer will be aggressive but doable. You might not be able to run 295s though..
Was your C2S lowered?
