993 Turbo Forum 1995-1998
Tires
Old Jan 16, 2009 | 02:26 PM
996racer's Avatar
996racer
Default Tires
I am sure this has been discussed before, but a search yeilded nothing. What is the max tire size you can go with on the 993 TT without butchering the fender wells?
Old Jan 16, 2009 | 02:45 PM
Barney1's Avatar
Barney1
I have a 305/30/19 on the rear..19x11.5 wheel
Old Jan 16, 2009 | 02:51 PM
V's Avatar
V
We need more info to be able to answer that question. It will depend on the width of the wheel, the offset of the wheel and the make of the tyres. On an OEM wheel, you don't want to go wider than 295s in the rear. With the correct offset and width, you can run tyres in excess of 315 depending on make without rubbing in the rear..
Old Jan 16, 2009 | 05:13 PM
ScottMellor's Avatar
ScottMellor
Depends also on your car's camber and ride height settings.
Different brand tires with the same nominal size have different actual widths.
