Average cost for Clutch Slave and Accumilator replacement
Thank You
Alright need top replace Clutch Slave and maybe Acuator. What does this usually run?
I don't know but I have a new slave in the garage for 2 months now and it will be a winter DIY project. In the DIY section there is a good write up on how to do it. It's not easy. Takes about 4-5 hours.
I have learned with this car just to take a deep breath and take your time.
Parts were under $1K for both (CS & A) and 4 to 6 Hrs of labor (on a lift) depending on diag and clean up if leak in trunk.
It must be the season, as had mine done a month or so ago, I updated my thread on the topic.
https://rennlist.com/forums/showthre...34#post5957134
Thank You
Thanks!
Loosen the motor mounts as much as possible and remove the driver's side heat pipe for much better access. Also R&R the top hose closest to the engine after you disconnect the unit from the bellhousing.
