Fan belts. Anybody have part #'s
My belts are squeeling. Looked up part numbers on PET but am a little confused. Does anybody have those reference numbers handy? Need all three.
thanks, Jaime
thanks, Jaime
Rennlist Lifetime Member
Should the first number be 999.192.343.50?
And note the altenator belt varies on whether or not the pulley update has been done.
The earlier pulleys can crack, the later pulleys are thicker and stronger, and eliminate the spacer washers that go under the alternator shaft nut and behind the inner pulley half. If you do a search on the NA 993 board I'm sure you can get the part # for the update kit. Remember to use only the original Porsche belts, aftermarket belts can cause misfire codes, seen it several times.
