obd bulb
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Hi chaps tedious I know but OBD bulb gone, I wasnt going to bother changing it but nearly crashed trying to see boooost reading,is there a lot involved looks like steering wheel /air bag has to come off,
cheers Gary
cheers Gary
You don't need to remove the steering wheel to get it out, you could loosen the padded dash top which gives you the little bit of extra room you need. I've taken mine out several times in the past this way and not had a problem, saves the hassle of the airbag and possibly damage to the slip ring.
Hi perry cheers mate done it already! nice car, does anyone know when you switch ign on does 0.8 bar flash up fpr a mili second then 0.0 felix said if the obdshows 0.8 when not under boost the sender is faulty? just fitted a nice sony head unit with crossovers plus ipod conection fantastic! better than 6cd and no weight
Gary
Gary
My sender boost gauge doesn't flash .8 when I start up, I only get that under full boost.
When I purchased my car the electronic boost gauge showed .2 most of the time even at idle, so I replaced the gauge and crush washer and all was sorted. (After the initial install I was still not getting a reading, but it turned out that the new sender was faulty, but this is a pretty simple DIY.)
There are instructions on here, do a search for faulty boost sender.
Good luck.
Good luck.
