993 Turbo Forum 1995-1998
Suspension
Old 08-25-2007, 02:31 PM
wst125
8th Gear
wst125's Avatar
Default Suspension
Where can you buy the factory ROW suspension? Also, is this the best suspension to go with without sacrificing the ride?
Old 08-25-2007, 02:32 PM
IamSMC
IamSMC's Avatar
www.carnewal.com
Old 08-25-2007, 04:51 PM
wst125
8th Gear
wst125's Avatar
Do they offer the cheapest price?
Old 08-25-2007, 07:20 PM
jimhsu
jimhsu's Avatar
does anyone have a picture of the 993TT set up with ROW M030, and could you also specify how much it was lowered?
Seen many pics of "lowered" 993TTs but never know how much are they lowered. Thanks!
Old 08-26-2007, 01:34 PM
biiig-hp
biiig-hp's Avatar
I had the MO30 on my car when I got it and did not like it. It worked fine on the street but was terible on the track. I think you can do better for not much more money if your going to make the change.
Old 08-26-2007, 02:24 PM
sfbanchs
sfbanchs's Avatar
why not get coilovers your standard shocks r probably in need of replacement anyway
Old 08-26-2007, 04:39 PM
wst125
8th Gear
wst125's Avatar
What are your suggestions other than coilvers? I don't not track the vehicle.
Old 08-26-2007, 04:45 PM
911/Q45
911/Q45's Avatar
Don't discount coilovers like the Bilstein PSS-9, they ride better than stock on the street and are not a tough install. Coilover is a bit of a radical sounding term, but in reality it's not track only.
Old 08-26-2007, 05:27 PM
wst125
8th Gear
wst125's Avatar
What is their price compared to the MO30 suspension upgrade?
Old 08-26-2007, 05:53 PM
Felix
Rennlist Lifetime Member
Felix's Avatar
Where are you located?
Old 08-26-2007, 07:02 PM
wst125
8th Gear
wst125's Avatar
In Texas
Old 08-26-2007, 07:30 PM
OldGuy
OldGuy's Avatar
PSS9s were the best thing I ever did with my TT but I would suggest GT3 sways with them. They stress the OEM drop outs. The OEM shocks last about 10K miles- if mine were shot no way I go back to OEM suspension. PSS9s with 3-4 Front back for the street and 1-2 front back for track are just excellent.
PSS9s are about 2000-2500 if I remember correctly and then you can lower your car to ROW height.
Old 08-27-2007, 12:53 AM
IamSMC
IamSMC's Avatar
http://p-car.com/susfaq.html
Old 08-27-2007, 01:28 AM
jimhsu
jimhsu's Avatar
Originally Posted by canysmc
Awesome page. Thanks.
Question from reading that: here is a quote from that P-car Web page,
The 993 Turbo already had the M030 sport chassis with the exception of a slightly firmer rear spring to compensate for the heavier rear weight.
Does that mean Turbos already have M030 springs?
Old 08-27-2007, 01:54 AM
IamSMC
IamSMC's Avatar
It appears the difference between USA and ROW Turbos is:
http://www.carnewal-europe.com/cpx_p93063.htm
Euro springs for front and rear.
Factory M030 shocks for the rear.
21 mm stabilizer bar for the rear
2x 21mm rubber bushing for the rear stabilizer
Search front and rear axle:
https://techinfo.porsche.com/techinf...SA_KATALOG.pdf
It appears the Turbo springs are M030.
With all this confusion regarding USA/ROW/M030 springs, I highly suggest going with th Bilstein PSS9 setup. With this setup, you'll being changing the shock and the spring as a matched coilover set. Most Turbo owners have gone this route. Search PSS9. There a plenty of threads on it.
Here's a picture of my TT with the PSS9.
Quick Reply: Suspension
