Auxilary Oil Cooler Plumbing Question
When plumbing an auxiliary oil cooler on the 993tt, should the oil go through the primary oil cooler first or the secondary oil cooler?
Or to put it another way:
If you are looking at the primary oil cooler from the passenger side, there are two outlets. Lets call the rear-most one number 1 and the other number 2. Which one should be connected to the low (inlet) side of the auxiliary oil cooler?
It may be 6 of 1 or half a dozen of the other, but I wonder if the brain trust has any input.
The reason I ask is I have two cars sitting side by side that are the opposite of each other in this respect.
For a cargraphics/ruf type of cooler on a street car my tech is recommending going from the primary to the secondary so as to lower the temperature of the air blowing across the ac condensor.
