DIY on lower valve cover gasket on TT?
I am looking for a DIY for replacing the lower valve cover gaskets on a 993TT.
Or actually I am looking for the information on how and what to remove to be able to replace them (exhaust, turbo etc.).
I was quoted 11 hours labour for replacing both gaskets, is it really that time consuming to replace them?
Regards, Peter
Regards, Peter
It's a pain with the turbos in place. You can replace them without removing the turbos however. Either way, it ain't an NA car. If you remove the turbos, 11 hours is a reasonable time.
1 Post
here's hoping some guru willing to share expertise educates us with a DIY thread for lower valve cover/gasket change for 993TT, because I am eyeing these:
http://imagineauto.com/Merchant2/mer...=IAVALVECOVERS
I'm Still Jenny
Barney (maybe the username is Barney1?) has some pics of what was removed when he upgraded to the billet covers.
Ryojo (Basal Skull) did a nice write-up of his upgrade to Kevin's turbos, which involve a lot of the parts removal necessary to get to the lower valve covers, let me go try to find it for you. Good luck!
Edited to add link:
https://rennlist.com/forums/993-turbo-forum/393382-diy-turbo-fpr-oil-check-valve.html
Edited to add link:
Last edited by WHB Porsche; 12-30-2007 at 11:01 PM. Reason: I thought it wasn't Ryojo, but then I figured out that it was!
1 Post
Thanks Charlie! I have searched many times, but it's your recollection of the thread that helps.
Where in NYC do you live, and what's your favorite "escape route" to get the TT out to the open road?
I'm Still Jenny
I live in Downtown Brooklyn. I really haven't had the chance to get out to some twisties, but upstate NY does have some excellent roads up around Hunter mountain which are definitely worth a summer drive.
Green993TT..... There is no easy way to remove the lower valve covers. Rear bumper off, mufflers off, cats off, turbos off, and then you can remove them. This is the correct way to do them. Make sure you purchase a good set of after market covers. I got mine from Haggart Machine. This is the company that makes all the covers for resale. Take your time, you dont want to do this twice. PM me with your e-mail address and I will send you pics.
Also, while you're in there, you should consider replacing the exhaust lifters. It's an easy job. The lifters aren't cheap (Pelican has them for $45.75, Sunset for about $70 last a I checked; both are INA brand) but as Barney said, you don't want to do the job twice.
Great point..... I also did the lifters and the car for one has never been more quiet and more responsive.. I had 3 lifters collapsed...
1 Post
Barney1:
thanks for the pics! Are those jackstands on the standard jacking points just front of the wheel wells?
And, I understand the turbo off, and the cat/muffler off. But the bumper cover off....sorry for my ignorance, but I am too ignorant to understand immediately why.... It must be much easier to get the turbos off with the bumper cover off?
One more question: are the turbo diverter valves in easy reach with this degree of exposure? I think I see it near the turbo. If so I can also do the billet diverter valves at the same time?
Barney1:
The diverter valves are on top of the engine, you can't get to it from below. If you meant waste gates, on our turbos, they are part of the turbo unit.
