993 Turbo Forum 1995-1998
Best way to lower a daily driver
Old 01-07-2002, 01:26 PM
Fred H
Fred H's Avatar
Post
Does anyone have details on the rear shock machining procedure? As I attempt to do as much DIY as possible, I am curious if it be performed on a small metalworking lathe or if it requires a shop with more machining capability.
Thanks in advance!
Old 01-07-2002, 01:43 PM
jessejames
jessejames's Avatar
Post
Originally posted by Fred H:
<STRONG>Does anyone have details on the rear shock machining procedure? As I attempt to do as much DIY as possible, I am curious if it be performed on a small metalworking lathe or if it requires a shop with more machining capability.
Thanks in advance!</STRONG>
What he said...
Old 01-07-2002, 06:27 PM
PramTT
PramTT's Avatar
Post
I was watching the Andial technician when he machined/shortened the shaft on my 993TT rear shocks. You need to precisely yet gently clamp the shaft so as not to damage the smooth part of the shaft or you are going to have leaking oil from the shaft seal. My advice, only to be performed by somebody that know what they are doing.
Pram
96 993TT
Quick Reply: Best way to lower a daily driver
