993TT Boost Gauge Reading
I recently purchased a 993TT that was supposedly set at 1.1 bar as part of a turbo upgrade package done by Weissach in Vancouver. The digital boost gauge, however, never reads above 0.8. Does anyone know if this is a factory setting - meaning this is the highest this gauge will read or should I take the car to my mechanic to check the actual boost level? Thanks.
Rennlist Lifetime Member
It is in the gauge. Just like the C2T it stops at .8. You will need to run an additional gauge if you want to see how high you are running. Andial sell the one that goes in your vent.
Stephen
Stephen
Thanks guys - I figured that was the case. There is definitely more kick than in a standard TT, but I will have my tech check the boost level when I take it to his shop just to be sure.
I wish that they had continued to use the analog boost gauge as in the 930s. There is something about that little guage that is so fun to watch -
