Cleaning Inside of Turbo Wheels
Anybody know of a brush or other tool to clean the inside of 18" turbo wheels while mounted on car. All brushes I see don't fit between caliper/rotor and wheel.
I typically use a soft sponge or older wash mitt, PS21S Gel wheel cleaner and LOTS of water and elbow grease. When I get at all of the surfaces inside each wheel, I then roll the car forward a few inches to expose the previously blocked spaces and do it some more. Back breaking, but effective. Good luck!
I agree with Viken and Nick about using a traditional mitt or sponge rather than a brush. I'd be concerned that you might nick the paint on the wheel or calipers if using a tool with a wooden or metal handle, due to the tight access. I use the same automotive car wash soap that I use on the rest of the car.
A trick that has helped me is to wax the entire wheel once in a while. The wheels are painted, and the waxing really reduces the ability of brake dust and other junk to adhere to the surface. I usually quickly wax them when having to remove them for some other purpose, such as bleeding the brakes or changing tires.
This makes washing "less" of a chore - though it is still a chore. Kind of reminds me of the sit-up portion of my work out. Important body part to exercise, but clearly my least favorite and the part I usually leave to the end and try to rationalize skipping!
I use a bottle/glass brush from the local Kmart. It has sponge material for the head and a plastic handle. It fits neatly between the caliper and the wheel and since it's plastic I can use it vigorously without damaging the wheel itself. Costs about 50 cents.
Guest
Posts: n/a
The means and methods that others have described for cleaning inside 18" Turbo wheels are all very effective. However, if you are still interested in a wheel brush, then visit www.performanceproducts.com. Performance Products sells a 15" flexible wheel spoke brush (part 883168) which can simplify the task of cleaning inside wheels of all sorts.
Basic Sponsor
I use a narrow radiator brush found at a local hardware store. It is only about 3/8" thick, like a wooden slat with bristles.
John
John
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
I approach this job using many of the techniqes mentioned above. I use a long handled flat brush available at any grocery store(sold to clean toilets, I think) to reach through to clean the rim surface, followed with a sponge. I use a narrower, wood handled round "grill brush" to clean the wheel surface at the front disc - allows me to clean this area without rolling the car. I clean the backside of the spokes with a small sponge. After I've dried the car, I drive around the block and then wipe clean the inside surfaces of the wheels. Finally, I also wax the wheels frequently. Every time I go into a new hardware store I check out all the brushes, etc. to see if I can find better tools for this purpose.
Thanks to everyone for responding to my question. I'll try the wheel cleaning methods you guys suggested and get back with results, if anyone cares. Thanks again.
