Fitting K-24s
Hi guys,
I'm finally taking the plunge. Whoever said it's a long slippery slope wasn't half kidding...
I'm fitting a set of K24s'
. My tuner has confirmed that I have the 430-450 Hp factory upgrade ECU which accounted for the 1.1 bar boost readings on full throttle (thanks for that bit of info Autobahn) among other things. With the fitting of the K-24s I should be seeing 480-500 Hp (hopefully!) Will update when car's out of the shop with possibly actual dyno results. If anyone has any words of advice or tips on what else I should look at while she's in there, it would be appreciated. My current setup:
Factory 430 ps upgrade ECU.
S oil cooler
K-16s
K&N in stock filter box
No cats
PSS-9s.
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
'00 Trackmagic 125cc shifter kart
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
S oil cooler
K-16s
No cats
PSS-9s.
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
I'd also install a 5 BAR fuel regulator... Also, make sure your turbo tubes are in good shape and the orange ends. Be REALLY careful of the oil lines going to the turbos. The one on the passenger side is almost impossible to change (there is ZERO clearance at the engine for a wrench).
Good luck....
Good luck....
Thanks Bob. Quick question, would the DME have to be remapped to accomodate the 5 bar regulator or does the 5 bar fuel presssure come in only at high boost situations (hope the question was clear??)
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
Thanks Bob/Scott. Scott, my tuner has actually recommended the cargraphics intercooler. Unfortunately my bank balance won't stand for it at the moment <img border="0" alt="[crying]" title="" src="graemlins/crying.gif" /> It's going to be breadcrumbs and water for a while (with K-24s on the side
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
Don't know the actual boost specs on the higher hp cars Sameer. All I know is stock is supposed to be 0.8 bar whereas my HKS gauge reads about 1.1 bar at full throttle. Anyone know where this data might be or at least a broad corelation between boost and Hp?
At 1.1 bar I'm pushing the envelope on the K-16s so I decided to upgrade to the K-24s. I'll be dynoing the car while checking the AFR to find out how it all comes together.
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by krish:
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Actually, the K-16s cant move enough air to produce more than 1BAR. Anything over that and you are just making more heat.
If you are taking the plunge for the K-24s may I suggest you try and get the "Race Version" with the ceramic impellers and the smoothed/polished internals. If you get the standard K-24s (retail is around $1,400 each) you will see alot of lag on your car especially if you are running a full exhaust.
I have the K-24 Race setup on my car (they were bought through FVD $2,900 each) and my car builds boost just above 2,000rpm. I am at full boost by 3,200rpm (1.1 or 1.2BAR).
My turbos whistle even at idle.
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Victors quote: If you are taking the plunge for the K-24s may I suggest you try and get the "Race Version" with the ceramic impellers and the smoothed/polished internals. If you get the standard K-24s (retail is around $1,400 each) you will see alot of lag on your car especially if you are running a full exhaust.
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Victor, you are a bad man <img border="0" title="" alt="[Wink]" src="wink.gif" /> . I just managed to convince myself and my bank manager that the K-24s were a sensible financial proposition and you fill my head with "race version turbos" <img border="0" alt="[nono]" title="" src="graemlins/nono.gif" />
Seriously, thanks for the tip. Would love to have them (they sound great!) but can't justify the expense (saving up for a pair of 'solos', whole different vice). I have dropped my cats though with test pipes in now so I'm hoping I won't suffer too much loss of bottom end, only time will tell
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Victor, you are a bad man <img border="0" title="" alt="[Wink]" src="wink.gif" /> . I just managed to convince myself and my bank manager that the K-24s were a sensible financial proposition and you fill my head with "race version turbos" <img border="0" alt="[nono]" title="" src="graemlins/nono.gif" />
[/QB]</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Sorry. I thought it my duty to inform you just in case you were able to sway your bank manager into coughing up just a little more money.
Let us know how they work out once you get the car back. <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Krish,
You might want to look around a little. I found a set of K24 Hybrids (Porsche factory EVO Motorsports units) for like $1200 for the pair on eBay. They only had 3,000 miles on them, and were PERFECT (previous owner just wanted MORE power). So deals are potentially out there...
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica"> Quoted by Victor:
Sorry. I thought it my duty to inform you just in case you were able to sway your bank manager into coughing up just a little more money. Sigh, Pigs would fly first.....
Let us know how they work out once you get the car back. Will do Victor, cheers
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica"> </font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica"> Quoted by Bob:
Krish,
</font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Sweet deal Bob! <img border="0" alt="[jumper]" title="" src="graemlins/jumper.gif" /> Wish I could get so lucky. But will take note of your advice with a timeline. If I can't find a good deal out there in thirty days, I'll just get my tuner to drop in the K24s. So if anyone hears of any good deals out there please pm me.
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
Krish,
cheers,
Kris
'97 993tt
'89 535I
'89 Nissan 300zxtt
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by viperbob:
<strong>I'd also install a 5 BAR fuel regulator... </strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Bob,
out of interest, how many bar is the standard FPR ?
