View Poll Results: What is the effective mass savings?
Voters: 30. You may not vote on this poll
Clutch weight savings poll
I thought it might be interesting to see what Rennlisters think about a LWF and clutch assembly. How effective is it, how does it impact our performance.
Guess what is the effective weight savings that you realize when you move from a stock clutch to a racing clutch..Weight savings of assembly: 12lbs.
What you are looking for is what sort of incremental weight would your engine need to push forward in 1st gear when you move from a race setup to a stock setup...?
No answers please other than on the poll.
not sure if I should say anything but there's a link from another thread on the 993 board that gives the answer! I assumed it was an 'unsprung' weight type of thing and it's sort of correct...
Depends on what gear you're in - that's why Jean specified 1st gear!
Yes I posted the poll before that post, quite a coincidence. Funny, I had posted the same question on that thread but then deleted my post in order to post it here as a poll. It seems like it got picked up.
I think the answer is too interesting for it to be within a different thread. First gear is 209lbs! I also did some acceleration simulations and the results however are not really tangible. First gear being so short, you would gain probably a tenth up to 40mph or so... Not bad though. Other gears there will be hardly any difference.
The data that I have is from Sachs, and I am posting here their calculations for clutches that apply to Porsche. I applied the same to our 993TT gearing a few months back and was planning to post it, this is the opportunity.
Thanks for taking the poll.
Originally Posted by Jean
And you own a tippy and all!!
Originally Posted by Ima2nr
is this why a rear wheel conversion is supposed to be better? even though you lose traction in the 1st 2 or 3 gears? overall is it worth the sacrifice of all wheel drive?
The benefits are:
Effectively about 10% more power/torque (compared to 4WD)
Steering feel to die for - makes 4WD feel positively agricultural
~45kg weight loss which helps traction as well as many other aspects of driving.
Negatives are:
The extra power/torque gained make the car more "lively" which some may not be prepared for
Powersliding is harder to achieve with the same finesse
You can't call your car a "turbo 4"
