993tt performance mods
I live in Milwaukee and need assistance in locating a reputable shop to install performance mods on my '96 993tt (ecu,cat bypass, rsr mufflers, light weight flywheel/clutch and bilstein suspension). Any assistance would be greatly appreciated.
ECU, cat bypass and RSR you can DIY with a little patience. The money you save could be almost enough for some nice AC jackstands and floorjack. Even the Bilstein you could do with a little help from someone with experience...only the clutch/flywheel will be a challenge for a newbie. You may also want to check the 993 board (and the FAQ) as there is more traffic there. <img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Hello, Wisconsin!
I'm just down the road from you.. KellyMoss Motorsports in Madison is the place to go..THey can handle anything you would want to throw at them..Ask for Fritz!
<a href="http://www.kellymoss.com/indexmain.htm" target="_blank">http://www.kellymoss.com/indexmain.htm</a>
