993 Turbo Forum 1995-1998
Squeaky Windshield Fixed!
Old Dec 9, 2006 | 08:10 PM
bigimp65's Avatar
bigimp65
in home depot today for some stuff and happened across the weatherstrip etc section. they had something called poly foam caulk saver, which is a polyurethane cord 1/2 inch in diameter that is normally used to pack deep gaps before caulking. picked up a 20' roll for cheap, stuffed it under the rubber seal as mentioned above, and WOW!!! creaking 95% eliminated!
Old Mar 9, 2007 | 02:17 PM
cesar's Avatar
cesar
Did you put this foam around the whole perimeter or just on the bottom/corner part like a U shape? Essentially the lower have perimeter.
Thanks in advance.
Old Mar 9, 2007 | 04:05 PM
911/Q45's Avatar
911/Q45
Stick it in anywhere it fits around the whole perimeter. You're trying to minimize movement of the glass.
Old Jun 11, 2007 | 06:38 PM
911/Q45's Avatar
911/Q45
Update on this old thread. My windshield started squeaking again, evidently the packing compressed enough over time to allow movement again. I just packed in some more foam and it quieted right down.
Old Jun 11, 2007 | 07:43 PM
pstoppani's Avatar
pstoppani
One track day is enough to get mine squeaking for a few days. Then it seems to resettle and quite down. On hot days, it squeaks more.
I've learned to accept the squeak and turn up the stereo
good thread though.
Old Jun 11, 2007 | 07:49 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
I typically use a thin wooden stick to peel back the rubber and a finger to help push the foam cord into place. It really makes a difference!
File Type: jpg
Old Jun 12, 2007 | 05:02 AM
C.J. Ichiban's Avatar
C.J. Ichiban
Platinum Dealership
wow great camera work chris! i need to get some of that when I get home next week...
Old Jun 13, 2007 | 12:26 PM
CAHRERA's Avatar
CAHRERA
Amazing Fix. After reading this thread yesterday I went down to the dealer and picked up some rubber cord P/N 996.541.903.00 Got home and installed it in no time. Drove the car and no more squeeky window shield. 98% noise is gone as far as squeek and cracking sound.
Old Jun 13, 2007 | 12:42 PM
AOW162435's Avatar
AOW162435
Seared
Does anyone have a closeup pic of the 993 windsheild without the outer gasket?
Andreas
Old Feb 1, 2008 | 03:39 PM
brucec59's Avatar
brucec59
Just wanted to add my feedback on this. The foam rubber cord (996.541.903.00) works! Took some effort to install in places, and there was one spot where there was too much black goo in the gap to fit the cord in (my windshield was replaced a few months ago). But the creaking is GONE! Woohoo! Cost under $21 w/ tax. Now if only I could find such an easy fix for the squeaky brakes...
Old Aug 9, 2009 | 05:27 PM
The Brewmeister's Avatar
The Brewmeister
bump
Old Aug 10, 2009 | 04:00 PM
nr1416's Avatar
nr1416
Did this fix 2 weeks ago. Worked like a charm!!
Thanks.
Old Aug 11, 2009 | 12:40 PM
brucec59's Avatar
brucec59
Since I posted on this old thread, I should give an update. The squeaking did come back after a few months, so I pulled out the cord, which looked rather compressed. I had enough new cord to do almost the whole windshield again. And again, no squeak.
So, it seems that this is a periodic maintenance item, and the amount that you get from Porsche under that part number is enough to do it twice.
Old Aug 11, 2009 | 03:39 PM
Barney1's Avatar
Barney1
FYI...I did this mod a few years ago and today I noticed a small amount of rust on the bottom left of the windshield. I'M PISSED..... When I took all of the foam out you should have seen the amount of water that came out with the foam. My car never see's rain either. Just car washes... Just keep an eye for such a problem. I'll deal with the sweek..
Old Aug 16, 2009 | 04:39 PM
911/Q45's Avatar
911/Q45
When you insert the foam you want to be sure that the rubber seal covers it completely, there shouldn't be any foam visible. Also, if the windshield is replaced be sure they paint the scratches in the channel that inevitably occur from removing the old glue.
