Car runs like a dream
Part 1 Engien compartment
A some of you know i have bought alot of stuff lately, and this weekend it was time to do a big maintance...I started to remove the air filter box and the interior fan assembly after that i decided to remove the intake manifolds just to check and get full acces to everything, i also removed the fan and the altenator. After this it was time to install all new parts, first was the new plugs going in. A set of Denso IK22 was on the menue to be installed, left side was not so hard, but when it was time to do the right side i did understand this is going to take some time..
..Nr 4 and 5 was not so difficult but nr 6 took like 1 hour to get out..but after i did do a lite search here on rennlist of the little hole from inside of the wheel whell it took only like 15min..![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Next thing was installing my new 8,5mm new magnacore sparkplug wires, not so hard execpt for nr 4 that was big fight for space between ic hose and sparkplug boot, but i did win at last...
.. After that it was fuel filter time, nothing hard about that just some tight space to work at..I also replace cap and rotor when i was in there.. the cap and rotor was not looking so good and same with sparkplug so it was time to do this..
Nex up was a RS Pulley and some new belts, this was straight forward, i also installed new hood shocks front and rear...and some new interior filters..
Now it was time to start putting everything togther after cleaning everything up...The car runs like a dream now not a hesitate, nothing it just pull very strong to red line....
Ps: My new diverter valves hasn't arrived yet so i will need to go in there soon again..
