why do you get more hp with larger turbos?
been re-reading TB993tt and fc-racer's posts on this tread.
I have a FVD ECU and also notice a surge in power to about 4000-4500 rpms, feel a little dip, then power rebuilding/increase in acceleration from about 5000 and up until redline/rev limit.
If the ecu is pulling timing/activating wastegates at 4000 rpm d/t knock/high boost (with standard turbos/standard boost levels), why do you get more power with larger turbos and more boost - why is there no knocking and ecu pulling timing etc. and limiting power with larger turbos?
May be I just don't understand turbos/engines enough...?
Larger compressor, properly sized = less intake charge heat.
Less intake charge heat = less detonation
Larger turbine & AR =less revesion
Less reversion= less detonation
Better boost control = less boost spikes
less boost spikes = less detonation
This applies to ANY turbocharged motor regardless of fuel used. FWIW I blend in race gas for a added measure of safety.
To answer your original questions: why larger turbos, and higher boost yield more power? In a nut shell: more fuel in the combustion chamber.
The fact is, more fuel (burned properly) means more power. Since the engine displacement is fixed at 3.6L, the way to get more fuel to burn is to squeeze more air (read oxygen) into the chamber for combustion needs. Bigger turbo and higher boost squeeze more air into the combustion chamber.
Obviousely this is the simplistic explanation. The proper execution requires the proper tuning of the ECU, the fuel injectors, the boost control, engine cooling, (more power= more heat), and down stream air flow, as the more air you squeeze in up front, the more air must flow out after combustion. So it is a very complicated tuning art, more so than just up the turbo size and boost pressure.
If I'm wrong I'm sure other turbo gurus will jump in and make it right.
CP
CP
Originally Posted by CP
"as the more air you squeeze in up front, the more air must flow out after combustion"
CP
CP
I guess K24's second post answers some of it. I will also video what the boost guage is doing next time I am 'pushing' it.
I understand about getting more fuel/air into a given displacement. I was wondering if timing is being pulled already with stock turbos, this implies to me that the motor is reached some sort of limit and adding more boost (fuel/air with larger turbos) wouldn't improve on this?
My turbo's are stock, 94 octane gas (r+m/2 I think), FVD ecu for stock turbos/'premium' gas.
I was wondering if timing is being pulled already with stock turbos, this implies to me that the motor is reached some sort of limit and adding more boost.
Here is what we do. You show me the boost video and I will tell you expected compressor outlet temps of your turbos. Then I will show you expected compressor outlet temps of another compressor option. It is this temp difference that will largely dictate the density difference between the two turbos.
Lower temps= denser air
denser air+ more fuel = more power.
colder air makes the car more restant to detonation.
Your car would benifit from larger turbos with your current program. You have several options available to you.
Well, in stock form the K16's will struggle to run at your 1bar ECU settings consistantly. If you jump under your car and adjust the wastegates 2mm+2 turns you will improve the bump or transition that you feel.
Kevin, so my waste gates may be opening prematurely/K16's struggling to maintain boost rather then timing being pulled?
I've read your previous posts on waste gate adjustement - so 2mm or 2 turns clockwise/shortening the rod may help?
I think I'm starting to understand - larger/more efficient turbos = lower temps = more power (not just shoving more air/fuel in at higher pressures).
K24's are not the solution for everyone .
Every K16 hybrid that I manufacture has a A/R manipulation that reduces exhaust backpressure.
Installing electronic boost controllers is for tuners that can't tune Motronic 5.2.
If you start with a factory set of K16's then they are sync'd!! Running them up 2mm will still keep them in sync.. You just have to mark the nuts and keep track of there rotations...
I have 2 German tuners that agree with me vs you.. And I can prove it with data on the dyno.. The N75 frequency valve can be controlled by the ECU to give you the boost that you need and want safely.
Tuner write XX program with XX components. Mr customer does not have same XX components and his wastegates are adjusted slightly different. Guess what? Now your mail order program is out of calibration and you end up with less boost than was tuned for or you have boost spikes.
I have no doubt that Gunther tunning any car will get the boost logs nailed. Its how it behaves in the other 25 cars thats the difference. EBC's don't share the same problem. They look at accual boost to make adjustments.
Basil, yes you want to shorten the rod. With your new boost gauge installed, you can watch how the boost comes on through the midrange then starts being pulled. If knock counts are low, boost will come up to a certain point in the RPM range. At 5200-5400 at 1bar things are pretty much spent. What one has to realize that when you install a larger compressor wheel on the same turbine wheel, the actual shaft speed slow down and actually reducing the exhaust backpressure. The reason is because the larger more efficient (hopefully) compressor wheel is producing more air per revolution. In the end the the target boost is reached sooner and one shifts.. the cycle is repeated. Please note that through my latest round of dyno data logging with factory and aftermarket IC, I have found that up to 1.35 bars of boost and 6000RPM the factory Intercooler does very well at keeping the charge air temps below 100 degrees.. However, over 6K the temps increase dramatically.. This data changes in very hot climates..
Thanx Kevin , I'll watch my boost gauge and give adjusting the waste gate a try. Not quite sure what happened/I must of missed something because all of Tom's posts seemed to have dissappeared..
Ryojo
Ryojo
