Windshield replacement
Hi,
I just bought a '97 993TT. It's a fantastic car, and overall, it's in great condition. One problem is that the windshield is fairly pitted--enough so that driving into the sun creates a big visibility problem.
For replacement, should I stick with OEM glass (e.g., from a dealer) or are the aftermarket versions OK? Any concerns about noise/sealing problems? I've heard about the squeaking problem, and although I don't believe my car has it now, I want to make sure I don't get it with a new windshield.
Finally, any recommendations for installers in the Los Angeles area (preferably west side) would be appreciated.
Thanks,
-Jeff
Thanks,
-Jeff
Jeff:
There are a lot of things that can go wrong with a windshield install; inner seal, outer seal, VIN plate, antenna connection, power booster, rearview mirror mounting, A-pillar trim, dash squeaks, etc. It won't cost much more to get it done at the dealership, and you'll never regret having it done right.
Ric
Ric
If you do a search on the 993 forum you will see the overwhelming consensus is non OEM glass. OEM glass is at least double the price and it pits just like the one you have now. I just replaced mine with Safelite and couldn't be more pleased... and only $600. The installer does a lot of 993s so there was no worry there either.
Rob
Rob
I had OEM glass installed by local independent glass shop known for careful prep work. It was covered by State Farm and I just paid the $500 deductible. Full price parts & labor was around $1200.
I watched the entire install and installer scraped away all old gasket material and black sealant. Then, on any areas where paint was scraped away there is a black primer which is applied, then a black silicone is applied. It is quite an involved process and the installer must be conscientious about proper prepping of materials.
Thanks for all the responses.
Based on the feedback I've gotten from several of you here, and after talking to a couple of installers, I've decided to go with an independent glass installer.
My decision basically came down to the realization that the dealer techs are most likely less experienced with windshield installation than a glass specialist. I'm sure the number of windshield replacements they do (assuming they don't farm out the work to a third party) represents a tiny fraction of the installations done by a specialist.
Thanks to everyone who replied.
-Jeff
-Jeff
Technical Guru
