Carnewal's Lightweight Flywheel Conversion
Originally Posted by pstoppani
What else do you need to know?
I have the same setup as sold by Gert at Carnwal. I'm using it with Kevin's Stage 1 which is good for about 450-470HP depending on octane so I'm not stressing it much.
Anyway, the clutch feels about the same as stock as far as pedal feel goes. The lightweight flywheel does make starting from a stop a bit trickier than stock; it's easy to overrev the motor or release the clutch too quickly. But it isn't a big deal. I can hear a bit more transmission noise when lightly accelerating but not a big deal either.
As expected, motor revs up and down more freeling.
If I were to do it again, I'd put back the stock flywheel. Given my car is a daily driver that sees a track day maybe 5 or 6 times a year, the daily drivability is more important to me than the performance improvement of the lighter flywheel.
Originally Posted by 911/Q45
And if everyone keeps asking the same questions over and over, it gets pretty boring and repetitous.
Have any of you guys actually picked up a dual mass flywheel?? Do you realize the added weight to your drivetrain.. Porsche only went to the dual mass unit because to many people complained about a little noise, and people didn't know how to feather the clutch..
My view of the lightweight clutch is to relieve some of the stress from the rotating assy/drivetrain.. Throw the performance aspect out the door.. Especially if one is tracking there car, or increasing the HP..
Originally Posted by Kevin
The kit you are linking to, what does it cost, i have tried here in Sweden today to get the Sach info and prices from Sachs, and they was rediculs expensive
I would love to get the Sach part nr if anyone are willing to share
The Sach's Motorsports parts are expensive.. Email me..
Yes i know the Sach parts is expensive but i think there is like 50% more expensive here in Sweden, but always funny to compare
The info i did come over here in sweden was a pressure plate giving 680nm and pared thougter with a organic disc giveing 15% more, will yield a 780nm, but the one one the link is holding more then 850nm stated, any more info on this..?
Wow, you guys only have one standard weight of lightweight flywheel?
In RX-7 world we have 2-3, with an aluminum flywheel w/ steel insert being lightest (about 12lbs total w/ counterweight) and steel which is about 16lbs.
stock for my car is between 22 and 28lbs, mine is the heaviest at 28lbs and is horrible, also has most of mass at edge of flywheel which makes it feel like even more weight.
I bet if someone were to come out with a milder streetable LWF it'd do pretty good.
just my2c,
-Ben Martin
just my2c,
-Ben Martin
Technical Guru
![](http://members.rennlist.com/jandreas/964-993-GT3-LWF.jpg)
Richard I upgraded my clutch (993TT) with the same "Viper Bob" package
that several others on this board did. Bob can you explain what was in you old
kit. I believe it was a Sachs pressure plate (#?), and I know it was a ltwt flywheel.
V. Bob??
BTW mine had quick engagement Richard, which you mentioned as a non-issue,
and mine had very high clamping force!!
Marty K
V. Bob??
Marty K
Hi Richard,
I ordered the Sachs motorsports unit (clutch and light weight flywheel) from Kevin along with his Stage 1. Once I receive and install all the components, I'll give you my feedback. By the way, my car is my daily driver...
Regards,
Ziad
Regards,
Ziad
I have bought a LWF now, i did find a used one just tried ones, the customer didn't like it so they removed it
I did get a deal i think, only 300 dollar for it
Originally Posted by Ziad
Hi Richard,
Regards,
Ziad
Regards,
Ziad
