Cooling down TT
HKS have the best one on the market. Not sure if they have wire harness for 993tt.
http://www.hksusa.com/categories/?id=1091
I have to admit that I don't let the car cool off at all before shutting it off (except at the track where I let it cool off for at least 5 minutes).
And, I have no intention of doing it, even if it is recommended. That's just a plain pain in the ****! I bought the car to enjoy it and not baby it. I'd rather have the turbo seals replaced more often than set at a gas station for 2 minutes before shutting it off... In my view, if the car needed a turbo timer, Porsche would have put one in...
Pete, Porsche has requested it's owners to idle the car temps down. The heat soak is also tough on the ceramic liners in the cylinder heads.. All the heat just radiating.. I have to upload some pics..
I just don't see how there could be that much more heat in these cars compared to any other car after driving it normally around town... In the end, the heat is a function of power so if you drive it normally, the power output is low and hence the heat output is low.
What am I missing?
I say to cool down these cars everytime, to at least 2 min.. However, try to at least do it 1 minute.. There is never a short grocery run in these cars.. If you guys seen how your headers and turbines heat up and glow in just moderate boost levels you'd be cooling the engine down. Again it is the oil that we want circulating through the bearing housings, and sump system.. It is the oil cooling down the topend, valvetrain, rods, pistons.. We don't have the luxury of water-cooling..
Here is a picture of a turbine wheel from a 993TT that has 55K on the clock. The 2 owners did not give a **** about cooling the engine down, let alone the turbochargers. If you can look at the shaft you have a blue temp moving from the turbine wheel head all the way to the compressor side bearing and past it.. That 700 degrees folks.. If you look closely at the turbine wheel you can see the knick taken out of the blades.. This is NOT from valve train damage but the ceramics cracking and breaking up out of your exhaust ports. The customer was so upset that he did a top end rebuild which included replacing 2 cylinder heads.. $1,400+ each..
I must also note that I put this wheel in the hot tank for 8 hours. You can still see the carbon build up around the cooked sealing ring. The bearings on this turbo were okay.. As I have always said, these turbochargers don't have a problem with it's bearing system. But due to heat, it takes a toll on the sealing components.
Thanks Kevin! I'll try for 1 minute cooldowns and we'll go from there
So, out of curiosity, I'd like to see pictures of my turbos (since Kevin has them as cores). They have 38K miles on them, 4 owners, and I put 6 track days on them.
Kevin, can you post the pics when you get around to using my old turbos?
