993 Turbo Forum 1995-1998
Leak Down Test - failed!
Old Sep 22, 2005 | 06:38 PM
Kevin Ross's Avatar
Kevin Ross
Default Leak Down Test - failed!
Hi Everyone
My car has been running a little rough and a few days ago the CHECK ENGINE light came on, so I asked Porsche here in Melbourne to check it out. They did a leakdown test, and there was a lack of proper compression on a couple of cylinders!
The quote is around AU$5500!! Ouch
Who was it that mentioned the slippery slope?...
Old Sep 22, 2005 | 07:00 PM
Acropora's Avatar
Acropora
Don't forget the new connecting rods, flame rings, and dual plugs when you're in there!
Actually that's a real drag. Sorry to hear bout that.
Old Sep 22, 2005 | 07:19 PM
strato58's Avatar
strato58
How many miles on the motor??
Old Sep 22, 2005 | 08:22 PM
911/Q45's Avatar
911/Q45
Just think of all the plump juicy things you can do while you're in there!
Old Sep 22, 2005 | 09:23 PM
Bill (NC)'s Avatar
Bill (NC)
Kevin, that's a bummer. If you are using a Porsche dealer get the service manager to check with the Porsche Service rep to see if they will pick up any of your bill. If not a dealer try and talk to him yourself. I had a carbon problem and a seat belt that didn't work and they picked up HALF the cost of both, just by asking! Saved about $4K. Never hurts to try.
Old Sep 22, 2005 | 11:09 PM
rinlv1's Avatar
rinlv1
Kevin, Sorry to hear that. That is a big bummer....
What kinda compression numbers did they give u??
Old Sep 23, 2005 | 12:40 PM
Woodster's Avatar
Woodster
think of it as a wonderful "opportunity", LOL!!!
Just crate it up and send Motor to Todd @ Protomotive!
Mk
Old Sep 23, 2005 | 02:56 PM
frisbee54's Avatar
frisbee54
Hi Kevin sorry to hear of your problems I had a similar situation right after I bought my car and just spent the $ and set the car up just how I wanted it, of course the unexpected expense is never a good thing when it comes to cars I wish you all the best and that you get your car back soon mine took 4 mos Doug
7 Porsche Models That Have Aged Like Fine Wine
Old Sep 24, 2005 | 10:41 PM
Kevin Ross's Avatar
Kevin Ross
Hi Again
It looks like just maybe the dealer that I purchased the car from will come to the party. Not sure what I will be up for now, but at least that is a good sign.
The leak down test revealed a couple of cyls were not getting the right compression but I am not technical, so I cannot tell you what they were getting... I only looked that the graph momentarily and saw that they were about half or just less than half of the others...
Now, while the engine is opened up... you guys mentioned doing a bunch of things... what things should I be doing?
Thanks in advance!
Old Sep 25, 2005 | 12:14 AM
911/Q45's Avatar
911/Q45
I'll start the list of possibilities:hybrid turbos from Kevin, head work, 3.8 P&C, cams, twin plug ignition, lightweight flywheel, stronger rods.
Old Sep 25, 2005 | 01:00 AM
ca993twin's Avatar
ca993twin
Even if you are going to leave it stock, I'd change the rod bolts, the valve guides, and the valve spring retainers to ones of better quality.
Old Sep 25, 2005 | 09:23 AM
Kevin Ross's Avatar
Kevin Ross
ca993twin, do Porsche make better ones now, or are there OEM parts I need? If OEM, what brands?
Thanks in advance!
Old Sep 25, 2005 | 09:25 AM
Kevin Ross's Avatar
Kevin Ross
911/Q45 - sorry I am as non-technical as it gets, what does 'head work' mean... in this context, that is
Old Sep 25, 2005 | 01:45 PM
Kevin's Avatar
Kevin
Kevin it is porting and polishing or fine hand machine work of your cylinder heads. It could include the install of larger valves..
Replace the stock rods with Carrillo's
Definately install higher lift camshafts
Twin plugging the cylinder heads is a plus
It's only money..
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
