PSS9 with RS Sway installation ... HELP!!!!
I am having the PSS9 system installed and got this note from the shop today:
________________
""John,
the drop links that came with the PSS's are not fitting.
the OEM sway bars fit much better but only reach two of the holes.
Have you heard of this before?
BJZ""
_________________
Here is what I have given them to install
PSS9 GM5-8044-H0
front bar 993-343-707-81
2 bushings 964-343-792-06
left sway bar end link 993-343-069-80
right sway bar end link 993-343-070-80
2 end link nuts 999-084-624-09
rear bar 993-333-707-81
2 end links 993-333-073-80
2 bushings 477-411-313-c
Any idea what the problem can be?
Would anyone who has had this combination installed give me the name and phone number of their installer so that I can refer my shop installing mine to them? Call them for advice?
The guys doing my install are Wright Tuning in Cincy (Batavia), OH.
THANKS for any help!
J
________________
""John,
BJZ""
_________________
PSS9 GM5-8044-H0
J
From http://www.rennsportsystems.com/993.html
The RS front bar is a 24mm, 5-way adjustable unit and the rear RS bar is a 20mm (22mm for GT-2) 3-way adjustable unit. These come with all necessary brackets and droplinks. The stock front droplinks for a C4 or C4S will clear the front driveshafts except for the frontmost hole.
There's a picture there also.
________________
""John,
BJZ""
_________________
PSS9 GM5-8044-H0
J
________________
""John,
BJZ""
_________________
PSS9 GM5-8044-H0
J
