Air Mass Sensor replacement, good investment
#32
I'm Still Jenny
I looked about a month ago and they were $440 on all the internet parts distributors. Now they're $550. $400 is a steal.
#33
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
No problem - I bought mine from them mostly because they are on my way home from work and I needed (wanted) to get it installed over the weekend, a few weeks ago.
#36
I'm Still Jenny
Thanks guys
#40
I have a used one that turned out to be fine, ie. no difference in performance after change that you can have for $200.00 if someone needs one
Bosch part number 0 280 217 809
#43
I'm Still Jenny
Thanks Kevin, I just spoke with Steve Weiner and he said the same thing. Ugh. Here's the description "This is not a Universal, This is an exact Original Equipment Replacement that is guaranteed OEM Quality and Fitment meets strict Porsche Standards." The internet sucks sometimes...
#44
I'm Still Jenny
One more question for you guys - what type of tool should I use to remove/replace the primary O2 sensors? I think I need some kind of socket as the tightening torque is specified, but judging from the service manual illustrations I don't think I can fit the first tool in this below space:
![](http://buy1.snapon.com/catalog/OBJECTS/19100/19028.JPG)
Should I use something like this:
#45
Rennlist Lifetime Member
In my opinion you don't need a torque wrench to tighten the sensors; just hand tighten until you can't turn them any more and then another 16th to an 8th of a turn after that with a wrench.
You may have trouble getting the old sensors off. I'm not sure that socket will work; it's probably too long to fit in the tight confines of the 993tt's cats. You can use a conventional box end wrench if you cut the wires and then use the open end wrench to tighten the new sensors. Or use the crow's foot wrench as in your second photo for both steps and you can hang on to your old sensors for years thinking you might want to reuse them some day.
