Diverter valves
Originally Posted by ttAmerica RoadsterAWD
Also, what do the diverter valves look like and where can I find them?
Jaime
Jaime
I was going to post these for future reference for guys like me that searched but could fine help or pictures. The right side is the most visable after the removal on the a-box and the air flow sensor. Do that one first and feel the hose clamps. The left side is the most difficult to get at. As Steven said you have to remove the blower motor after the intercooler of course. I used a 1/4 inch drive with a 7mm socket. Don't even attempt to use a flat head screw driver. Being familar with it after you remove the right side you can do it.
This pic is the left w/the screw driver point to its location.
One thing I did on the left side was to loosen the lower hose clamp first, then I located this hose clamp below the throttle linkage running back toward me. It is the other end of the 90 degree hose at top of the diverter and more easy to remove at this end than reaching through that maze and better on my back too. At that point you remove the top hose clamp put the new diverter on, secure the top 90 degree clamp first where its right in front of you. Not easy to explain but you will see this when its in front of you in person.
Corte Loco,
If your girlfriend is that generous with Porsche mods, can I borrow her for a few months? My birthday is coming up soon, you know. (I only want to borrow her for the presents, of course)
