996 seat fit in 993?
I've written about this a few times; 996 seats will bolt directly into a 993 with no fuss, no muss. There is no bolt hole misalignment. I installed GT3 seats out of a 996/986 into my car and had *no* problems bolting it right in. The stock 996 sliders put the seats higher than I preferred, so I bought the Brey-Krause side panels which helped bring me down to the right height. I know this information is contrary to early reports on 996 seat fitment into a 993, but, much to my surprise, these seats went in easily and mated up with the 993 bolt holes.
So, the 996 seats don't "require" the B-K panels, but, as Jean said, they will help with height issues.
Click this link to read about my experience dropping the GT3 seats into my 993.
There should be no issue putting a stock 996 seat into a 993, except for the wiring connector. I think these changed from 993 to 996.
Good luck.
Good luck.
Originally Posted by Rob 97 993c2
do we know if the B-K height adjustment brackets will work with a power motorized seat, as well as the manual sliding seat (gt3)
i called b-k several times... they have no answer on the topic and have not considered it.
i told them that many pre996 owners would care about this, so they are looking into it.
There are two fitment issues I think: (1) the fit and width of the mounting brackets; and (2) the fit and width of the seats (the seating area and the shoulders). If you look at pics of 993 interiors (incl mine which I have previously posted) you will see that clearance around the shoulder area is on the tight side.
Dave- the physical size of the 996 seats are no bigger than 993 seats. It is all about the installation on the rails and power.
Tom - i am interested in discussing your seats, but need to know that it will work as i dont want to buy them and have them not fit properly. I have yet to find someone that put electric 996 seats into a 993 and have the height and movement be correct - nor have a seen a bracket adaptor for the power seats. Otherwise, im delighted to discuss your seats, especially as you are local.
