oil leaking from turbo
put new turbos on car about 500 miles ago
the car has been sitting in the garge
notice a small leak from turbo were it bolts on to the flange
any ideas
rocket930
any ideas
rocket930
New or rebuilt? Have you added oil to the engine level lately? Pull the intake boot and see if you have oil on the inlet side of the compressor.. Did the shop prelube and purge the inlet lines..
Edit.. Which flange the Cat, or ?? Are your valve cover gaskets leaking.. Is the oil inlet lines tight and not leaking from above...
