Quick question. Should the heat shield be oriented as pictured, or rotated 90 degrees anti-clockwise? Was mounted 90 degrees anti-clockwise from pictured, but I thought it looked off as it then doesn’t prevent heat from the muffler hitting the turbo. Right side of vehicle.
The way you have them pictured is wrong, needs to be turn 90 anti clockwise as you say. More to protect the engine/valve covers, mufflers aren’t really affected by radiant heat.
@Basal Skull
Thanks.
That’s what I noticed too. On the left side the shield is lower between the muffler and the turbo. But then I will take it back to how it was mounted before.
Just replaced hoses between turbos and intercoolers plus som other small bits.
Can I have one of your spares?
@Basal Skull
I put on OEM hoses, but with constant tension clamps on both ends. I see your point. The oem ones are a hair short.
I also removed correctors on the lambda sensor after the cats. The engine had some mods previously, but is now back to stock. I guess they are to avoid CEL. Will these correctors have any effect on the performance of the engine? Or does the ECU use only before cats lambdas as an input?
@Basal Skull
I don’t believe the post cat O2 sensors affect performance of the engine. I always fuss that a CEL may pull boost and put the car in limp mode, although a post cat sensor triggered CEL should just be emission related. I am not sure what you mean by corrector? Connector? Or do you mean a spacer to prevent a CEL , and you’ve removed them as you’re back to stock? Spacers should do nothing to performance. They do help prevent CEL tho.
@Basal Skull
Sorry. Meant spacers. They were called correctors on a site a buy parts… I shouldn’t need them with the engine being stock. But will find out when spring arrives
