wheel horspower
Can't answer at the wheels HP, I think the 993tt needs a AWD dyno that are not common but are available. Unfortunately the US Turbo S was rated at 408hp like the standard turbo.
Keep in mind all 993tt engine worldwide are the same mechanically, only the ECU and turbo's are different for the higher hp 993 models.
https://rennlist.com/forums/993-turb...dyno-runs.html
https://rennlist.com/forums/993-foru...995-993-a.html
Given 22+ years on, no two 993TT will be the same since factory new. Given the reverse "back of the envelope" thinking on 993 drive train loss % (lots of rennlist threads on that topic) for wheel Dyno to engine HP calc, would expect 15-18+% loss at the wheels 2WD and as @C4Spolar points out, have to then add in the front drive drivetrain loss too on the Turbo (unless removed). Thinking is 22-25% in total loss.
933tt US/CAN/ROW are rated at 408hp, 97/98 Turbo S are rated at 435/450 depending on engine package and the street 993 GT2 are rated at 450hp.
