993 and 993 turbo engine return oil pipe
HI
Does any one know what the difference is between a standard 993 engine oil return oil pipe and a turbo engine oil return pipe is please,two different part numbers and typical associated costs.
Happy holidays.
Wow! Got to think a customer pipe could be had for much less if you have a (damaged) original to match it to when making it. Possibly a hydraulic repair shop could fab (or repair) one for a lot less.
You own a Porsche, you pay. Simple!
fab oil return pipe
[QUOTE=C4Spolar;18531362]The problem with the oil return line "custom made pipe from an hydraulic shop" is the round crimped tube fitting that connect in the thermostat unit below the oil tank, that round metal fitting with 2 Viton ring seal crimped on the metal tube is Porsche proprietary. Same goes with the oil lines from the thermostat along the bottom of car to the oil cooler.
I've had a couple of pipes fabbed by a hydraulic shop. They take the metal portions of the pipe you have and fab the rubber in between. You have a new crimped on hose and the correct fittings on the ends of the hose and the cost is substantially cheaper.
JC 96TT
JC 96TT
[QUOTE=jac911;18531728]
Yes the crimped rubber hose portion can be replaced by a good hydraulic shop but the round metal end with 2 grooves at the end of the line that connect in the thermostat CAN'T be replaced if it leaks oil. That means you have to replace the line with a new one.
JC 96TT
JC 96TT
I have the Turbo Kraft oil feed lines and never get any smoking Cris. No expert but not sure you need the return lines. Try these and Merry Christmas
Merry Xmas.
Ronnie.
Again the topic is ENGINE RETURN LINE, not turbo valved feeding lines or turbo return lines. There is a big difference between an engine return line and turbo oil lines like your picture.
Start reading from the tread starter and work your way down.
Cheers.
This picture is an engine return oil line, as nothing to do with turbo oil feed lines or return hard lines.
Cheers.
Ronnie.Again the topic is ENGINE RETURN LINE, not turbo valved feeding lines or turbo return lines. There is a big difference between an engine return line and turbo oil lines like your picture.Start reading from the tread starter and work your way down.Cheers.This picture is an engine return oil line, as nothing to do with turbo oil feed lines or return hard lines.
