Anyone with a 993 turbo specific oil change write up…
Seems like our cars have officially turned old and rare enough that there’s no longer an easy online diy with photos for changing our oil anymore.
anyone have one?
anyone have one?
Boost Junkie
Just use any 993 NA diy you can find. The only thing different to add is draining the turbos which just needs a hex driver to remove the obvious drain plug in the bottom main surface
turdfarmer (06-25-2022)
Yup, nothing too special about oil changes on a turbo vs NA car. I do drain the oil sumps on the turbos just because it gets every drop out but I also pull the oil feed line that is just below the secondary filter because that lets out quite a bit more oil. All the usual rules apply, be really careful on the refill since the oil goes in really slowly once there are a few quarts in and the filler tube can overflow. Prime the filters by cranking with the DME relay out before startup - I usually do that after 7 or 8 quarts in the tank, crank until you see say 2 bar on the oil pressure gauge. When draining the engine case, hold the plug in place with a screwdriver and slowly tilt the plug to let out the sump oil slowly, otherwise if you just pull the plug it will gush and soak your left hand heat exchanger (never mind the mess).
Cheers,
Mike
Cheers,
Mike
rlme36 (07-16-2022)
Cheers,
Mike
Cheers,
Mike
rob
