Exhaust tips
Exhaust tips
The exhaust tips on the 993TT I took delivery of today are in dire need of some work - either a good polishing or a new set of tips. Are there any companies that make a good set of tips for the car?
Many of us have removed the mufflers and tips, and installed a muffler bypass system. I have the Fabspeed bypasses, and they come complete with nice looking tips. You get: a pretty nice sound, less weight, and better cooling flow to your turbos. The cost of this conversion is actually less than most tips alone.
Dr. G,
Yes, I ought to have noted that my Fabspeed tips bypass the standard muffler.
Steve,
Is there much involved in the RS short shifter & mounts conversion you've done to your TT? And, did you end up with the RS gear lever?
Steve,
CV,
The RS short shifter kit reduces the throws by around 20%, and required that the underside tunnel cover be hammered a bit to get the required clearance. Take a look at the carnewal stite... there is a rumor that a new kit doesn';t require the hammering. I dunno about that. The "shift ****" is stock and attaches to the new lever.
The RS mounts are no big deal to install, although I confess that I had Viperbob install mine for me. There are good instructions available on the web at that DIY site. I can't hear any extra noise or feel any vibrations... but then, I'm an old guy.
